cprezzi
(Claudio Prezzi)
July 6, 2018, 4:31pm
1
I found a solution how to config latest Raspbian Stretch so it works with Manga Screen 2 (in landscape) or HDMI Monitor without reconfig.
First sudo nano /boot/config.txt and insert the following at the beginning:
[EDID=IAG-MangaScreen2]
Settings for Manga Screen 2
hdmi_timings=1080 1 100 10 60 1920 1 4 2 4 0 0 0 60 0 144000000 3
max_framebuffer_width=1080
max_framebuffer_height=1920
display_rotate=1
Then sudo nano /etc/udev/rules.d/99-manga.rules an add:
ACTION==“add”, ATTRS{name}==“Intelligent Agent AS Manga Screen 2”, ENV{LIBINPUT_CALIBRATION_MATRIX}=“0 1 0 -1 0 1” #rotate 270 degree
Thats it! At least for me
Thanx for the tip, time to try it…
Oh that is awesome! Great catch!
Doesn’t work for me Claudio… I get 3 Pi desktops split across my screen in portrait.
cprezzi
(Claudio Prezzi)
July 10, 2018, 10:23am
5
My config is only valid for devices with an EDID of “IAG-MangaScreen2”. You can check your EDID with the command “tvservice -n”
@cprezzi I managed to sort it last night, i got confused with { and ( - all done and happy… My only issue is I want the orientation to be where the HDMI cables are coming from the bottom of the screen, not the top of the screen as per your config… any advice to rotate even further ?
cprezzi
(Claudio Prezzi)
July 10, 2018, 12:17pm
7
@Andy_Williams This could be done by changing display_rotate to 3 in config.txt and change the ACTION string above to “ACTION==“add”, ATTRS{name}==“Intelligent Agent AS Manga Screen 2”, ENV{LIBINPUT_CALIBRATION_MATRIX}=“0 -1 1 1 0 0” # 90 degree clockwise”.
@cprezzi Man, thank you ! Next up, orientation of the mouse is off now ! slide right on the screen and the mouse goes left - I’ll work it out ! Thanks so much for your advice
Tomas_Vit
(Tomáš Vít)
July 10, 2018, 3:25pm
9
@Andy_Williams I am precisely at this state. Thanx in advance for a note if you find a solution of both layers (picture, touch response).
@Tomas_Vit Hi Tomas, how do you mean both layers ? I’m working fine now, just need to reverse the mouse movements
Tomas_Vit
(Tomáš Vít)
July 10, 2018, 3:52pm
11
@Andy_Williams Yes, I have meant proper picture layer and sensitive layer justified and with cables heading down.
@Tomas_Vit Ah… I’ll cut and paste my config later. What are you using your screen for ?
cprezzi
(Claudio Prezzi)
July 11, 2018, 7:31am
13
@Andy_Williams Is your touch screen just left/right reversed or also top/down?
cprezzi
(Claudio Prezzi)
July 11, 2018, 9:48am
14
Ok, got it working. For Landscape with cables down, you need the following settings:
In config.txt:
display_rotation=3
In 99-manga.rules:
ACTION==“add”, ATTRS{name}==“Intelligent Agent AS Manga Screen 2”, ENV{LIBINPUT_CALIBRATION_MATRIX}=“0 -1 1 1 0 0” #rotate 90 degree
Tomas_Vit
(Tomáš Vít)
July 13, 2018, 3:12pm
15
@cprezzi It works. Lama question: Is there a possibility to use touch layer under Raspbian at all?
cprezzi
(Claudio Prezzi)
July 14, 2018, 12:58pm
16
@Tomas_Vit The touch is simulating mouse moves/klicks, but real touch gestures like pinch/zoom are not supported, as far as I know.
Tomas_Vit
(Tomáš Vít)
July 14, 2018, 4:15pm
17
@cprezzi I know, but can’t get any touch response under Raspbian yet.
cprezzi
(Claudio Prezzi)
July 14, 2018, 11:20pm
18
@Tomas_Vit Did you try with a normal USB cable?
Tomas_Vit
(Tomáš Vít)
July 15, 2018, 6:32am
19
@cprezzi Have tried two, will dig for more. Thank you for a tip.
cprezzi
(Claudio Prezzi)
July 15, 2018, 8:25am
20
I tried first with a very short cable of a power bank, but it sems this cable only has power wires but no data wires connected.
