I finally print something but I meet a serious problem right now. The 3D printer’s drill can’t touch the bottom of the class so I put a notebook under the glass.However, the procedure failed in process each time cause the glass is not stable. So how can I make the drill can touch the bottom of the glass? (birdcage)
Sorry I didn’t see this earlier. Have you solved the problem? This is one of the most common problems reported in the original Easy Arts forum. Unfortunately there are several different causes, like loose screw, short spring, mismatched firmware params. Solutions depend on the actual problem. I believe there are some other postings about this problem in this community as well.
Never mind. It seems you solved your problem
No I don’t solve this problem yet
