I bought a Synthetos gShield (v5b) board few months ago, but still were using Arduino Uno + grbl. Finally some days ago I decided to give it a chance. I flashed brand new Arduino Due with latest ‘TinyG G2 for Due + gShield 087-edge’ firmware using USB Programming port and the FW update feature available on http://www.chilipeppr.com/tinyg. Choosing right board from the list downloads firmware automatically - great feature from @jlauer .
Every first time I connect the Due/gShield to my PC I see Bossa Program Port (which I would normally expect with no TinyG firmware present) and not two TinyG ports. Pressing RESET on Due (or gShield) solves the problem until next time I need to connect. I replicated this already on two different Due boards - same result.
I tried to set the boot flag to 1 with bossac, same as when boot flag is set to 0.
Is that normal Due behavior or am I doing something wrong? I am quite sure this is Due and not the gShield causing this, but maybe someone got similar issues. Keep searching…
