I am running GCodePrintr on my Asus TF700 tablet running Android 6.0.1. Everything works except for the web server. What should I try to get it working?
Thanks!
Gene
I found that it only works when a printer is attached!
Matthias, is there a simple way to send a model? I don’t need to run most of the PC application.
Thanks!
@E_Risi I’m working on a gcode upload through the web interface. Until this is available the only way is to use the Gcodesimulator PC application or netcat to send the file.
