I am pouring through the wealth of knowledge here in this community, haven’t yet found this answer, so I am throwing it out to you guys…: Can I increase the Z height of the Spider V2 simply by purchasing longer smooth rods, ball screws, and extrusions? If so, I want to increase Z height by 75mm.
Assuming this is accurate…
The BOM links to vertical extrusions from Misumi with screw holes drilled relative the the edges, so simply extending the length of these (562mm to 637mm) should do the trick, thoughts?
And, smooth rod from 435 to 510mm?
Would these 500mm ball screws be appropriate appropriate (https://www.aliexpress.com/item/RM1204-Ball-Screw-L500mm-Ballscrew-With-SFU1204-Single-Ballnut-For-CNC-Processing-length-can-be-customized/1588730692.html?spm=2114.13010208.99999999.264.w6L2ba).
And, mad props to @Neil_Merchant , your build is nearly there - looking forward to see those first prints.
