unlikely to be due to those actions. I have found that the auto-levelling (in grbl) nearly always bugged out, but not every time. which is very difficult to chase down.
Since applying the fix above which is the null effect if no lyr.materal, it works every time (so far…)
Hmm, I’m going to try to put this code that @Justin_Adie wrote into the TinyG Autolevel Widget and publish it. This feels a bit dangerous doing before I fly off to Europe for 11 days, but since folks are having issues, this could fix it. I see that all Justin did was add an if statement testing for nulls so the code doesn’t error out, which I think makes a ton of sense to test for.
The auto-leveling widget is hanging again, but unlike previously closing the EagleBrd widget does not solve the problem. I have discovered pushing the auto-level widget’s pause button, twice (which causes it to report paused and then unpaused) continues probing, but only for the next location, as it hangs again immediately after getting a z value. I don’t believe that hitting the pause button used to have the effect. Thoughts or suggestions please?
Note that after pushing pause the second time, the probe moves to the next location, lowers to find z, then hangs again. Two pauses will get it moving to the next location, where the process repeats.
Just published a new fix right now. I think I messed up the previous fix and the new one should solve it. v2.1 is what you should see for auto-level widget.
