I am attempting to generate G-code for engraving with a CNC mill, but no actual tool paths are being generated. The resulting G-code file contains only the start and end G-codes (none of the other milling modes generate tool paths either). What is odd is that generating G-code for laser cutting does produce tool paths. I am using the latest (August 24) nightly version of LaserWeb4.
I have attached a screenshot showing the settings I was attempting to use. Is there anything I’m doing wrong, or is milling support currently broken?
