https://github.com/LaserWeb/LaserWeb4-Binaries/releases/tag/v4.0.990-115 New Tools for documents/objects: - [NEW] Select All,
  • [NEW] Select All, Select None
  • [NEW] Duplicate selected documents (ctrl+d)
  • [ENH] Remove selected documents button
  • [NEW] Apply stroke/fill color to selected documents. (Pick color, then apply with side button)
  • [NEW] Search thru document browser by object name.
  • [FIX] MDB apply Preset bug fix
I just tested the MDB. It seems to work. :slight_smile:
I’m a bit confused with the Z-Settings. Can you point me to the mistake a made?
@Todd_Fleming ​… sorry I don’t use milling. I suppose it’s go fast down to rapid z, say 4mm above material zero, then start at 2 (startz <4) and end at end z 0 if is drilling.
@enhydra ​ btw should be a diagram above operations explaining, isn’t it?
Thank you. Now it works. :slight_smile:
I had to set the “End Z” to a negative value (here to -2).
But still: The warning in the MDB remains…
