https://github.com/LaserWeb/LaserWeb4-Binaries/releases/tag/v4.0.734-96 - Long awaited feature:
@Jorge_Robles You should also update the server part each time you create the exe :wink: (it’s 4.0.96 now)
It could happen that I changed something in the frontend that need the correcsponding change in the backend. Or like this time, I promissed a feature in the issues.
I did… Double checked… npm kidding?
Where did you check? On github it sais 96 commits and in package.json is version 4.0.96.
Did git pull and npm update http://lw.comm
Will retry l8r
I do always first pull and merge lw.comm-server, then npm run installdev on lw4 to get the new lw.comm-server…
Oh ok
Or did you forget to merge master into electron-bundler?
Yep. That happened.
:wink:
SVG changes:
  • Automatically determines px-per-inch. Inkscape 0.92 is now usable without fiddling with scale settings or using an export command.
  • Fixed a bug with SVG group transforms
  • Supports rotated and skewed images in SVG
Probe Z, probe ma X, probe min X,probe max Y, probe min Y and probe Z don´t work. Nothing happen when this buttons are selected.
The same problem with home Z,X and Y.
G38.2 Z does not have moviment.
smoothie firmware edge-8e4a64c.
Using the menus from GLCD, the probe funtions work well.
Is there something desconected from LW?
thanks.
@Roberbike Probing and single axis homing is not implemented yet, sorry!
The command to home Z on Smoothieware is G28.2 Z
See http://smoothieware.org/zprobe for details.
@Todd_Fleming ​​ so no need for px point in settings anymore?
@Ariel_Yahni_UniKpty Not for Inkscape files :). It relies on optional fields in the SVG spec. If those are missing, then it falls back to the config value.
@cprezzi ok. Thanks for answer me.
