I want flashing bootloader using FlashMagic, but i can’t boot board into ISP mode.
Can you help me?
Thanks very much!
Imported from wikidot
Can you help me?
Thanks very much!
Does the board have an ISP or Bootloader button ?
The board is not open-hardware so I can’t really give you much help with it, I recommend you contact the seller.
The board doesn’t have ISP button, but it have i pin for ISP.
I have a board’s schemetic, but i don’t know how to insert image.
ISP goes to pin 2.10
Then the process to get into bootloader mode is going to look something like this :
That should do the trick
Why do you need to flash the bootloader by the way ? That’s not something people usually need to do.
Hi arthurwolf
because i want to flash firmware via usb cable instead of sdcard.
if use sdcard, sometimes user delete some file such as firmware.cur, config, etc. Then board will not use. So i want to flash the firmware to the FLASH memory of MCU.
I tried your method, but board can’t enter ISP mode.
When i release reset button, the board work normally.
I use Flash Magic’s terminal then type dfu command, the terminal display “entering dfu boot mode”.
But when see Windows Device Manager in COM port warning ! “smoothie”, that mean smoothie driver is wrong, althought it work normal in normal mode.
where i can find smoothie driver?
DFU is for linux only, won’t work with Windows.
Also, I don’t understand what you mean about needing to flash the bootloader : the bootloader is already present on your board, you don’t need to flash a new one …
Thanks arthurwolf
Because i want to flash firmware into board via usb cable instead of copy to sdcard.
Were you able to get this to work? I’m struggling with it now
