Hope I can get some help. I have used ChiliPeppr a while ago and always worked well. I decided to use my CNC again. Created my project on Fusion360 and exported the Gbrl code via Fusion360 Cam Postprocessing. When I simulate in Fusion360 everything is ok but when I simulate on ChiliPeppr instead of running around the circles to cut it just goes up and down the circle.
Here my Grbl http://txt.do/dv1a9
Run an airjob instead on your CNC. G3 circles in the viewer don’t animate correctly in the simulator.
