I purchased the starter end mill set from Brandon and i’m new to cnc so I was wondering if there is a guide to identify the end mills. Thanks for any help!
Looks like. 3mm 2 flute, 1/8" single flute, 1/8" longer single flute, 1/8" two flute, 4mm single flute, four different angle v-bits, and an 1/8" straight flute.
But you will need to break out the calipers for confirmation.
