Hi, We need your opinion.
Material/Operations Database will be overhaul next week. LW4 has exploded in options and the M.O.D. is not enough flexible to hold it all (yet)
What do you prefer when you go to do a laser job?
Job first then materials. So you can take your current operations and do it on another material
Same here, job first, material after. So you can do for example a quick wood prototype and if okay, switch to the final material like alu, etc.
Also if the material settings don’t work you change these, but not the op.
I would prefer a grid, with operations on one axis and materials on the other. Choose both simultaneously.
