Thanks for asking here – these are good getting-started questions.
There is no automatic conversion from strings to numbers in C/C++. So the code you posted is dealing all with strings, but then trying to assign them into places that required numbers (i.e., the led array). Also, you had quotes around what you were assigning into the leds, so instead of trying to assign the value of the variable A into an led, you the code was setting the led to the actual letter A.
Instead of using strings at all, try just using numbers throughout the entire program, more like this. “unsigned long” is a number wide enough to hold an RGB color code:
void setFairyQueenColors (unsigned long head, unsigned long chest, unsigned long robe)
unsigned long a = head;
unsigned long b = chest;
unsigned long c = robe ;
Serial.println(“debug fairyqueencolors”);
Serial.println(a) ;
Serial.println(b);
Serial.println©;
leds[0] = a;
leds[1] = b;
leds[2] = c;
FastLED.show();
Serial.println(“debug leds”);
Serial.println(leds[0]) ;
Serial.println(leds[1]);
Serial.println(leds[2]);
You can call this like this:
setFairyQueenColors( 0xF78CFF, 0xFFFFFF, 0x87ABFF )
No quotes are needed, because C understands these hexadecimal codes directly as 32-bit numbers.
Here’s an even simpler way: instead of “unsigned long”, just use FastLED’s “CRGB” color data type:
void setFairyQueenColors (CRGB head, CRGB chest, CRGB robe)
leds[0] = head;
leds[1] = chest;
leds[2] = robe;
FastLED.show();
You can then call that function with any arguments that are convertible to CRGB values, i.e., this still works:
setFairyQueenColors( 0xF78CFF, 0xFFFFFF, 0x87ABFF );
But now these work, too:
setFairyQueenColors( CRGB( 120,140,255), CRGB(255,255,255), CRGB(140, 171, 255 ));
and
setFairyQueenColors( CRGB::Pink, CRGB::White, CRGB::PeachPuff);
// All standard HTML color names are supported
Let us know how it goes! I’m sort of dying to find out what the FairyQueen is all about
