Hi. I wanted to sanity check this before I cause any trouble for myself. Is there any reason that I couldn’t use this display with the Cohesion3D mini:
Silkscreen seems to indicate AUX-2 and AUX-3 connectors rather than EXP-1 and EXP-2. Not sure if they’re equivalent.
Corollary question: is there a pinout for the GLCD adapter? The one I found in gut hub seems to be different.
I do have one here that I ordered to play with. Not going to get to play with it for a few weeks though. I think you’re a few towns over, if you want to give it a try?
Looking at it, the pinout is different than the reprap GLCD, unfortunately. It isn’t a direct plug in. Probably achievable with manually mapping the pins.
I do like it for its size, and it seems like it would have a better viewing angle than the RepRap GLCD.
Oh, and its got a place to solder an ESP-01 on the back. Not sure what that’s for, but sounds cool.
I have one of those on my big 3d-printer. It was not working until I got a special version of repetier from the supplyer. I think they need to be driven a bit different than the normal GLCDs.
