If you are using the Arduino IDE, then it will be in the libraries folder within the your “My Documents -> Arduino folder”. Rename the old version to something like FASTLED_old
I am using Arduino IDE but with Teensyduino installed and the ‘contributed libraries’ are not in that location … I can’t find where they are installed at all
still no luck unfortunately. I have a feeling they are in the ‘application data’ folder or suchlike, and i have recently upgraded to windows 10 and can’t seem to see inside those hidden folders, even when i change the folder view to be able to see the folders themselves
Also - remove the error check warning - there’s stuff that arduino has done in recent versions of their app that breaks the ability to check the FastLED library version in a .ino file (you’ll note that I’ve removed that error check from all the examples)
I knew there was a good reason that hadn’t upgraded to windows 10 The location is here c:\Program Files (86)\Arduino\hardware\teensy\avr\libraries if you can’t get to that location then I suggest uninstalling teensyduino and the arduino ide, then reinstall them but don’t tick the Fastled box in teensyduino. Usually this won’t delete your sketches from your documents folder (are least on windows 8.1), but it might be worth copying them to another location just in case
