Hi!
I experimented with the 1D 8 bit noise function and created this variant that directly generates noise in the range -128…127. No need to scale it, i.e. no _raw variant. The number of multiplications is the same for the not _raw variant, but the result looks very smooth. What do you think?
// generate noise in the range -128…127 for x in 8.8 fixed point notation
inline int8_t noise8s(uint16_t x) {
// integer part of x
uint8_t i = x >> 8;
// fractional part of x
uint8_t f = uint8_t(x);
// bump for position i and negative bump for next position
int8_t g1 = bump8s(i, f);
int8_t g2 = ~bump8s(i + 1, f);
// interpolate between the bumps
return lerp8s(g1, g2, f);
// average for 8 bit signed integers
inline int8_t avg8s(int8_t i, int8_t j) {
return (i + j + 1) >> 1;
// lerp for 8 bit signed integers. the interpolator r is interpreted as 0…255/256
inline int8_t lerp8s(int8_t a, int8_t b, uint8_t r) {
if (b > a)
return a + uint8_t(r * uint8_t(b - a) >> 8);
return a - uint8_t(r * uint8_t(a - b) >> 8);
// calculate bumps of varying height in the range -128…127
inline int8_t bump8s(uint8_t i, uint8_t x) {
int8_t hash = P(i);
int8_t y = uint8_t(x * x >> 7) - uint8_t(x + x);
int8_t u, v;
if (hash & 8) {
u = y;
v = y;
} else {
if (hash & 4) {
u = 1;
v = y;
} else {
u = y;
v = 1;
if (hash & 1)
u = ~u;
if (hash & 2)
v = ~v;
return avg8s(u, v);
