Hi fellows!!! I am searching the internet about LED control 3D mapping with Arduino(Teensy). What I want to achieve is to create a polyhedric structure with PVC tubes connected with 3D printed nodes and 2812B LED strips inside, connected to an Arduino board and MIDI controlled to synchronize music and lights… Every advice would be very appreciated
Ooh I hadn’t thought to use PVC pipe before. Are you using thin wall Schedule 40? Is that thin enough for decent diffusion?
With a flat strip will it only light up half the pipe, or does enough light bounce around in there to light up the whole circumference?
I’ve tried it in the thicker walled white pvc drainage pipe (3") with pretty good results. Used a toilet flange for a base mount
