How are the nano’s powered as in what / where is their power source and what / where is the pixels power source? I understand your grounds are good and all connected.
data cables are 150cm long. no ground wrapped data.
nanos are powered with the same 3 12v60a with which led strips are powered. grounds are good connected.
as explained, the system was working 2 hours before it started to fail. the only thing that substancially changed is the fact that the arms are now mounted in the metal structure, and of course the source of electricity, but I checked to electricity sources and it failed in both, while mounted to the metal structure
I have driven strips with 10 meters long cables without problems… Nevertheless is weird that changing the frequency to 800khz sorted out the mess, isnt it?
Yeah I’m running 5 ws2811 trees with a pair of cat5 cores about 5 meters with no problem. I guess some people have allot of noisey power supplies or something.
