So I bought a IR probe from Aus3D and it works fine. Their selling point was it triggers from 3 mm above the nozzle so no need for a servo.
So it homes the Z with about 2 mm to the surface but I’m trying all the offset workarounds like G92 Z2 but it doesn’t seem to move it past the trigger point. I suspect the probe is disabling the Z motor because it is an endstop after all.
Should I comment out the endstop mask for the Z and will redeem still know what input to look for when probing?
I have the same issue. I’m not sure if my probe type is set correctly the M558 description in the wiki is not very clear. whit this macro it works fine for the probing. but when I start the print it act as an end stop and don’t apply the probe offset.
my macro have surely something missing.
my g29 macro looks like this:
[Macros]
g29 = M561; (RFS) Reset bed matrix
M557 P0 X+0.00 Y+5.00 Z6.0
M557 P1 X+0.00 Y+166.67 Z6.0
M557 P2 X+0.00 Y+333.33 Z6.0
M557 P3 X+0.00 Y+480.00 Z6.0
M557 P4 X+200.00 Y+05.00 Z6.0
M557 P5 X+200.00 Y+166.67 Z6.0
M557 P6 X+200.00 Y+333.33 Z6.0
M557 P7 X+200.00 Y+480.00 Z6.0
M557 P8 X+350.00 Y+5.00 Z6.0
M557 P9 X+350.00 Y+166.67 Z6.0
M557 P10 X+350.00 Y+333.33 Z6.0
M557 P11 X+350.00 Y+480.00 Z6.0
M557 P12 X+500.00 Y+5.00 Z6.0
M557 P13 X+500.00 Y+166.67 Z6.0
M557 P14 X+500.00 Y+333.33 Z6.0
M557 P15 X+500.00 Y+480.00 Z6.0
G32 ; Undock probe
G28 ; Home steppers
G30 P0 S F3000; Probe point 0
G30 P1 S F3000; Probe point 1
G30 P2 S F3000; Probe point 2
G30 P3 S F3000; Probe point 3
G30 P4 S F3000; Probe point 4
G30 P5 S F3000; Probe point 5
G30 P6 S F3000; Probe point 6
G30 P7 S F3000; Probe point 7
G30 P8 S F3000; Probe point 8
G30 P9 S F3000; Probe point 9
G30 P10 S F3000; Probe point 10
G30 P11 S F3000; Probe point 11
G30 P12 S F3000; Probe point 12
G30 P13 S F3000; Probe point 13
G30 P14 S F3000; Probe point 14
G30 P15 S F3000; Probe point 15
G31 ; Dock probe
M561 U; (RFS) Update the matrix based on probe data
M561 S; Show the current matrix
M500; (RFS) Save data
