Hey guys quick question, anyone have a suggestion for blending the transitions between colors in this code snippet?
for (int i = 0; i < 20; i++) {
leds[i] = CHSV(0, 255, val3);
for (int i = 20; i < 40; i++) {
leds[i] = CHSV(0, 0, val3);
for (int i = 40; i < 60; i++) {
leds[i] = CHSV(95, 255, val3);
basically i have a strip of 40 ws2812Bs val3 is a variable to change the dimming of the strip via external controls, everything is in HSV. the first section of the strip (leds 0 - 19) should be Red, middle section (20 - 40) should be white, and last section (40-60) should be Green. it all works fine except i want there to be a blending of the colors right at the lines. so say between leds 17 and 22 red would blend in to the white. anyone have any ideas on how to do this easily?
