Hey guys, I’m having a lot of trouble with my printed Steering Block. The thing keeps breaking when I move the wishbones up and down.
Anyone with suggestions to stop this???
Adjust your steering endpoints lower as your servo is oversteering and causing the breakage
No man, the problem is when the shock absorbers go up and down.
Ah, still a bind, just in the up down movement instead of the side to side movement
This is not a very good solution, is it?
This is a offroad car, should be able to handle the full course of the suspensions.
But if it’s the only way
