Hi Stefano,
No sensor on my Eustathios, it hasn’t been necessary so far, the cast and milled 6mm aluminium plate with glass on top is flat and I only have to adjust it after a nozzle change.
Acceleration in x and y direction is set to 5000mm/s^2 for printing and 6000mm/s^2 for traveling
Z is 300mm/s^2
Jerk 20
Board is RADDS Arduino due, Steppers are RAPS128 with THB6128 chip. Although I can print @100mm/s, I usually do so at 60mm/s.
Max speed with Arduino due with 128 microsteps in my setup (16 teeth pulley on stepper, 32 teeth on rods) is 125 mm/s.
SW is Repetier 1.0
I never loose steps anymore since I changed to quality drivers and properly adjusted the current so the motors don’t overheat.
I have found lost steps to occur more from nozzle catches than from high speeds. Unfortunately the central carriage using bushings makes it far less compliant to catches than linear bearings would. Catches will cause a bind on the busing and skipping steps.
To confirm, Make a test gcode that is really fast, but doesn’t actually print filament. Start at a known position, Move around a bunch at high speeds, small moves, fast moves, etc. Return to the known location. My guess is if you measured start to end positions you would find no missed steps.
Also you can turn down acceleration. I found with testing, 2000 is more than enough to maximize print speeds.
Same here with a setup very similar to @Daniel_F (DUE + RADDS + Repetier). Lost step are always caused by a colision between hotend and filament. Must admit that this part of dialing-in, i.e. extrusion related, is the most difficult part. May @Daniel_F or @Eclsnowman can share their settings relevant to this. Running here an E3D Volcano with 0.4mm nozzle.
My main thing is not running too fast on small prints that have a tendancy to curl up because you can’t cool the layer in time before the next one starts. I also print outside perimeter to inside perimeter on parts that have a tendancy to curl (like overhangs). This tends to fight curling because the second or third perimeter pass is inside. I Z-hop on travel moves atleast 2x layer height.
I used to print fast on all things. Now I have more printer capacity than I need, so I slow down. 100mm/s is great, but if I have such a large print that printing that fast is needed… then I go to a bigger nozzle and slow back down.
I spend a lot of time dialing in my extrusion muiltiplier. Over extrusion is a sure fire way to cause a nozzle catch if you have fast travels. I set non-travel moves at 160mm/s. SO if you hit a blob at that speed you are certainly going to skip… expecially in PLA.
Once I have the steps/mm dialed in, then I run my extrusion multiplier around .98 down to .96 depending on the filament. This tends to lead to perfect top layers for me… but with no over extrusion to catch on.
@Stefano_Pagani I have the Duet/dc42 IR sensor, and I am running using it on Mega/RAMPS & Marlin. This is 7x7 mesh on backpainted 4mm glass on Mic6 plate with 3 point supports-
I have found that it really is not worth the auto bed leveling/meshing.
After all the time I have put into it, I am pretty much back to relying on a single, dumb microswitch for Z stop and I get as good, if not better prints with no fuss.
Thanks guys! I am going to skip the autolevel, my bondtech case (printed) fell apart so I am printing a better one. It wasnt retracting much as the gears were not meshing well.
I am going to rebuild my plate to be like walters design and use better aluminum.
