Hey all. I’m trying to put together my Eustathios shopping list, ran into this problem with the Misumi lead screws. This line in the BOM:
Lead Screws - One End Stepped Type or One End Double Stepped
MTSRA12-410-S56-Q8
The problem is, that the S value is limited between 3 and 40. S56 is not accepted. Is this a bug in the BOM? Or maybe Mitsumi changed their specs ? Or maybe I am missing something ?
I think misumi may have changed the options available for lead screws. The part # listed in the BOM was correct/available when I initially ordered it earlier this year. If someone is able to get in touch with them (Misumi) or some other merchant who will provide a suitable option, I’ll be glad to update the BOM.
Because there are different length belts needed. The Drives are run in the bottom area, and tie from the drives via a closed loop belt to the x/y gantry. Belt length to the top x/y bar is a different length than the belt to the bottom x/y bar. Then there is the closed loop z axis belt. Finally there is bulk belt used to tie the x/y axis to the drive pullies. Sdpsi has more selection for closed loop belts, but robotdigg is cheaper for bulk belt.
