Here is another render of the Talos Carriage:
The video shows the two modes for the carriage. At first it shows the Direct Drive extrusion mode utilizing the amazing @Martin_Bondeus Bondtech drive gears. Then you can see how the extruder can be easily removed just leaving the hotend. The hotend is mounted on the carriage plate in a groove and retained in place from below by the heat sink fan assembly. So in this mode it is perfect for Bowden use.
The rest of the video just shows how the rest of the assembly comes apart.
Hope you like it Alex. You did an amazing job on the design. I am glad you let me help a little with the CAD side of things documenting in Solidworks all your great work.
