I don’t know what type of switch/sensor OMTech is using on that machine to sense the distance to the material but it sure sounds like it’s not working. Broken wire maybe? I would recommend looking for the device/sensor used for sensing this Z axis and follow the wires from switch/sensor to the controller and make sure the wires are A-OK.
Also, can’t you manually back the Z axis up so it is well above the honeycomb bed so that you can stop it well before it hits it again?
If your ‘emergency’ off removes power, the controller will be reset, so it should not try to home unless the Z home option in the controller is enabled. I’m assuming it’s resetting and the Z axes home is enabled.
When you power it up, you can press ‘esc’ and it should stop it’s home operation… Giving you control of the machine.
There are lots of videos out there on struggling with an autofocus machine… Most of the people that I know for hobby use, have it disabled … I don’t have a Z axes control, except the knob I twist…
Until you get it figured out, I’d disable the Z home in the controller…
A couple ways of checking the hardware…
You can also check ‘Z/U → Diagnostics’ and see if the limit is being detected… This is detecting the Y axes…
Also note on the Ruida, these are not ‘limit’ switches they are labeled, used only to home (-)… at least the X and Y limits work that way. Real limit switches are rarely used on these machines and they are denoted by the + after the signal name… LmtX+ is the X limit input and LmtX- is the X home input.
