Hello,
I have used chilipepr grbl workspace for several days for generating gcode from eagle cad. I tried to make some gcode today but it seems that gcode for holes and for cutting plate dimensions is not generated. Sending gcode to workspace for simulation also doesn’t work.
Did anybody encountered this problem?
Everything seemed to be working properly the last time I updated the eagle widget in grbl. Can you try using eagle in /tinyg and let me know if everything works properly there? If so, you can copy the gcode generated into /grbl to run.
