I’m thinking of building my CNC router and was planning of using 12mm trapezoidal lead-screws but i am inclined to use these below linked cheap ball screws. its just over $15 un-machined end for a 16mm screw and nut 1000mm! Should i go for it or stick it much more expensive rolled trapezoidal screws with brass nuts?
+Peter van der Walt seen you telling somewhere in the community that you would better use a ball screw rather than belts and lead-screws, please give your opinion on this
forgot to mention that i have purchased quite some stuff from this seller and all are of good quality but never purchased these ball screws or any linear motion stuff from him.
£35.25 Postage to the UK takes a bit of the shine off so not so cheap really. Might be different wherever you are. Good luck with the build tho, at least that’s fun.
