Hello again group. This is my second question so far, but first I would like to thank those that offered solutions to my initial question. OX ran fairly well this weekend after I made some of the recommended adjustments. Z-axis motor was running very hot - Adjusted the pot for the Z-axis -seems to have made a huge difference. Although I do use shielded cable for everything, I did notice a couple of places where my limit switch wiring was running close (parallel to) some of the motor wiring - Moved them apart.
I looked through other questions for an answer but didn’t find it.
So my question this time is - How do I mark a question as solved so others might benefit?
Thanks,
Ted
