Having some problems hooking up the steering for the F1. Could someone take some pics of their steering setup? No matter what I do it binds and also hits the inside of the body. Thanks!
Since it’s not possible to add a picture in a answer I have posted pictures I a new post.
I had to trim a bit of the end of the servo lower off with a knife because it would rub against the front shell wall where the inset is… I used washers above and below the servo saver (upper/lower) to increase the tension on them.
