Has anyone seen this before? onewire / ds18b20 returning nonsense numbers? Not talking about the error-state numbers like -127 or 85, but just more or less random temperature numbers.
ESP-12e running at 3.3v, using GPIO5. Using Arduino IDE (1.6.7)
It used to work, but I was screwing around combining OTA update and the deepsleep command (bad combination). I think I corrupted something.
Same code, same ds18b on an ESP-01 works fine (using gpio0 for ow)
Try gpio0 on esp12… Did you ds.begin() ??
Thanks for the suggestions. I tried gp4 earlier, just tried gp0 now, no difference either way. begin() is the last call in setup(). It was missing, and I hoped it was that simple, but adding it made no difference. Gotta be something I’m missing…
Code is here, hope I’m overlooking something http://pastebin.com/CVqtrgMW
Do you change this #define ONE_WIRE_BUS 0 to select different pin??
Yes, changed the define and the hardware hookup for pins 5, 4 and 0… no change.
Its like there’s some sort of floating point math error, if thats possible? Here’s some of the readings from the code above
Temperature: 124.62
Temperature: 123.62
Temperature: -118.19
Temperature: -108.00
Temperature: -101.44
Temperature: 124.12
Temperature: -123.31
Temperature: 124.00
Seems i’ve damaged (corrupted?) the esp-12 module somehow. I hooked up a nodemcu (another esp-12) and loaded the exact same code on it, and it works perfectly. Same connections, etc.
Going to look up how to re-flash the firmware and see if I can recover the faulty module.
