Has anyone mounted F103 tires on the openrc F1? They are much closer in size to the ‘original’ tires than the F104 tires that many people seem to be using. if you have tried F103, what wheels did you use?
Front tire is 45mm wide 55mm tall.
Here is one site that sells them:
http://www.rcmart.com/shimizu-racing-ps0545-rear-slick-tire-tamiya-f103-p-31439.html?cPath=35_958
