Hi everyone,
I have a question about uart connection. I want to connect bluetooth device to control jog commands to sbase with GRBL-LPC.
I use TX0 and RX0 pins on sbase board.
in serial.c
#include "grbl.h"
#define USE_USB
#ifdef USE_USB
#include "usbSerial.h"
#else
#include "Driver_USART.h"
#endif
When I comment “#define USE_USB”, bluetooth work but not USB. When i uncomment it USB works but not bluetooth. Is it possible to make both working?
Best Regards
Cihan Alak
Jammy
(Julien Morris)
2
Welcome to the forum.
I had a quick look at the code. The use of #ifndef USE_USB throughout indicates it’s either \ or.
Besides that, you can only have one serial device connected to RX TX.
Thank you for your kind answer.
Is it possible to make both useable?
Jammy
(Julien Morris)
4
Possibly, but it would take a re-write of serial.c
Without digging too deep : Each function would need to check for a valid connection and attempt to read / write the data .
