GRBL 1.1 Running on a Smoothieboard
500 mm/s, 79,000 steps/s
0.3 mm pixel spacing. Join Pixels is Off.
LW3 (branch) streaming 1666 blocks/s over USB
Port by @Brett_Fleming and myself with advice from @Sonny_Jeon
https://youtu.be/jv0lxEan_Xw
Is this a firmware branch? If so #ShutUpAndTakeMyMoney
Runs on on smoothieboard?
A round of beers need to be added to all of your PayPal accounts!!!
+Peter van der Walt Will be testing this shortly.
If you generate using LW4, then you’ll have to strip out lines which only have S# in them. I don’t know why lw-rasterizer puts them there. They sometimes cause GRBL to slow down. We don’t know why yet.
Hats off to @Todd_Fleming and @Brett_Fleming ! They ported Grbl v1.1 in about two weeks, even after running into a deadend with a different approach. Beautiful job fellas. I have a feeling this is just the beginning.
For the curious: the largest deadend was mbed. They have unfixed bugs that have complaints dating back 4 years.
+Peter van der Walt ah-ha! Now it makes sense. Yes, please remove those.
Is there anything else needed to test other than installing the firmware.bin?
We can connect with GRBL reporting back ‘GRBL 1.1e…’, but nothing further and commands are unresponsive.
We are using Ultimate GCode Sender.
There’s a key difference between GRBL on Arduino and GRBL on Smoothieboard: opening the port doesn’t cause a reset. I changed LW3 to send a ctrl+x when it connects. Once it’s working, there are a couple changes to senders for them to run at full speed:
Before testing on a sender, I recommend connecting a terminal to the COM port to make sure it responds. I use PuTTY.
My LW3 changes are in the grbl-buffer branch; I don’t know if the ctrl-x will break TinyG or Smoothieware.
@Todd_Fleming Is there a way of detecting it is Grbl running on Smoothieboard? For example: a welcome string like "Grbl v1.1e (LPC1769)
Grbl sends the welcome string after each reset. Could you change that behaviour to send the welcome string after a connect (and reset)?
Should it work on an azteeg X5?
Really nice
@Todd_Fleming I have found that you set the default for $10 to 1 but LW needs 0 (WCO). Not a big deal, as it could be set with $10=0.
