Can you give more information on this please? It was reported as spam as posts with no content but a link usually are.
Here watch this video. A few videos say there are no differences so your mileage may vary.
@TOPE_designs Perhaps that is what I did not realize it is specifically designed for Delta Type printers? The one below is a Prusa type.
Here is one:
@D_T11 this mod he uses is 4 diod smoother that doesn’t work in deltas also … 8 diod is the deal ! try man you have nothing to loose and a lot to gain … cheers m8!
I spend less then 8€ ($9) to do the board that fit under my little printer,
perhaps I will do the fourth smoother to put on the boweden extruder …
@TOPE_designs Exactly. I agree a diode costs 20 cents. Or I can tear apart an old board and recover all the diodes I need for free.
I could put it on perfboard even. Really simple circuit.
