I want to upgrade my 40W laser to an 50W CO2 Laser.
I ordered the Tube and a new Power Supply. (Dy-10 50W)
And i ordered a Smoothieboard 4cx too
I added new Stepper motors and Laser Glasses
So my question is:
Did someone have a wire instruction? So that i can directly connect the smoothie to the Dy-10 Power supply? In the internet are very much confusing things
So i think that im here by the right side of laser blaster
Hey @Chris_Hurley , thanks for that. I saw it yesterday
My brain is actually a little bit confused of diagrams and plans in the internet.
I tell you my thinking, i hope its right.
The normal wiring is clear. Like Stepper and Power to Smoothie.
The only Problem that i have is the PWM connection from the smoothie to the HighVoltage Power Supply.
In my Smoothie Configuration i set the laser_module_pwm_pin to 2.4 so i get the Ground from the HighVoltage power supply to 2.4 and go from the other pin 2.4 to the IN port in the PSU and not in the L/TL. Then i i connect the 2.5^ smoothie pin to the L/TL pin on the PSU.
this pic helped me with my re-wire, and is my current setup with the exception that my laser psu has the green connectors.(and my 2.4 mosfet died so its on 2.5)
@Domm434 thanks. And now my confusing is complete i saw soooo much pictures The picture i post is my PSU can u just explain where i connect my Ground and PWM? Im very confused now
