Good afternoon
I done upgradeof my firmware-cnc.bin for latest version
Now i cant force machine to reference to bottom left corner where i have endstops
Every time it send head to center of table end setup 0 there
Is there any changes in configuration.txt?
When i use previous firmware(i was using one from november) all is fine
G28.2 should be the homing command once you switch to cnc firmware
Its not this,when i try g28.2 its freeze board now
G28.2 with a capital?
And if that doesn’t work you’ve got a problem somewhere else
Yes with capitals,on old firmware-cnc.bin all work fine
Advise you grab a new stock config file. Back up the current one obviously. Start from scratch and rebuild your settings manually.
actually homing in the CNC build should be $H as in grbl, don’t use G28.2
Sort it out my homing,now work fine .
Just need to chec why i have warning on Lw3
