Getting close enough in my printer build to need to sort the print bed.
Frankly, I would rather just use something on the market, but since my bed is close to 400mm x 400mm, the stock solutions thin out awfully fast. Also, especially for larger heated beds, using AC rather than DC makes sense - which further limits easily sourced beds.
If I were designing an ideal bed, the bottom layer would be some insulating material (perhaps cork), next the heating pad (silicone embedded?), a somewhat-thick aluminum plate (to spread heat), and perhaps a magnetically attached thin steel plate with top-coating (as with the Prusa mk3).
The insulating bottom will prevent wasted heat, and improve heat-up times.
The lower thermal conduction of the steel top layer will tend to force a more even heat distribution through the higher conduction aluminum plate. (Yes, I want to hijack Prusa’s mk3 work, which I assume is excellent.)
There is still a problem with the ensuring the top surface is flat.
We can get milled or “tooling” aluminum plate … at much cost. We could hope that ordinary aluminum plate is sufficiently flat. Or we could accept multi-point “auto-leveling” as always required of an on-temperature bed (rather often).
We could use borosilicate glass as the top - an inexpensive flat surface, that does not distort with temperature. Thin glass is easily shattered if the print head descends a bit far, or other stress. The low conduction of glass means the bed would take longer to temperature, but should give more even heat distribution through the underlying aluminum plate … though if the aluminum plate is not as flat as the glass, uneven contact might mean uneven heat in the glass.
Right. Stacked trade-offs … just not what I want …
For reference, Sanladerer has some excellent videos:
If I could ensure sufficient volume, there are likely … with enough engineering … more economic solutions. But just now I want to get my printer built, not design a new print bed … so … trade-offs.
