Trying to use up my off cuts so making another charcuterie board and wanted a carved design on it. I may or may not fill with epoxy depending on how it comes out.
But this is what I came up with using AI image generator and height map generator. Used 2d software to reduce noise and clean up image a little bit.
So if anyone wants to make a charcuterie board, here it is the pattern.
For this one, it was 100% AI generated. You throw in a single image and it creates the depth map from it.
There is a race war between different organizations/companies to make a height map generator. Google, Adobe, Microsoft,…etc are all developing their own. The one I used was Marigold depth estimation model.
There are several other height map generators I am playing with right now.
