First two color print. Still need to clean it up but it came out better than I expected
That’s gorgeous. What’s your setup?
Hi Nick
Printed on a duel head Leapfrog Creatr Printer. Item is from thingiverse
On slic3r, under the file menu I used the combine multi STL function and exported a 50% scale AMF file. I wanted to test it first before the longer print time on full size. This is the 50% print. I will print full size today. One small issue is in the hole cleaning out support material to make the surface perfect.
