First time ever posting on G+ so sorry if I do something wrong or take a while to reply.
Earlier this year I bought the Smoothieboard x4 and installed it into modified K40 laser (new gantry) followed a few guides online and got it installed and software setup and started cutting, after a few minutes the control board would crash the leds would show VBB (on) 3v3 (on) 4 (on) 3 (off) 2 (on) 1 (off) none of them flashing. Hit the reset on the control board, restart job and if I am lucky I could get it done without it crashing again (70% chance of it crashing)
Recently had enough and contacted RobotSeed and they sent me a replacement and upgraded it to the 5x board, just installed the board, sorted out the config and start to cut and… crashed again.
I can leave the control board on for hours and 0 crashes, start cutting and it crashes, seems to only crash when the laser is firing so its either a level shifter issue, power supply or the tube.
Does anyone use a level shifter? I am using a 3.3v <> 5v Arduino one, seen a few guides without one, and 2 with one. So not sure if I should be using it or not.
Not sure what to do next.
Anyone have any ideas?
