Feature idea:
Base-mode
Just start/pause and a load file button.
No temp checks
No lines
Nothing.
Since some devices have problems with lag, why not build a mode that you can activate and that only has the core features you absolutely need.
To be honest: If my print is running well, I’m not monitoring anything, most of the time I’m not even in the same room, so I don’t need any of these other features
@Jakob_Dobberow there is already an option to turn of temp checks, lines are not printed by default anyhow, so only the gcode rendering remains and I can certainly add an option to disable it while printing.
btw. GCode Printer App is exactly GCodeSimulator&Printer without the gcode rendering.
Ah ok, cool, i’ll try that
@Jakob_Dobberow I have just implemented a feature to disable gcode rendering during print. it will be in the next version.
Ahhhhhh, nice one, thanks a lot
