Fans don’t turn on when config-override is on the SD card?
But will turn on when config-override is not on the SD card.
But I need the config-override on the SD card so the Z max is correct.
Is there away to fix this?
Thanks
Thanks
config-override has nothing to do with fans, so there must be some other issue, maybe a bad sdcard? try a fresh new sdcard. or reformat the current one. and start with a new config.
