ey people!
we are working on controllin ws2811 via artnet through ethernet. You can check the approach in the link below.
In the new version of the library is possible to state the RGB order in the code, but I havent found this possibility in this code or in FastSPI_LED.h
Any hint?
thanks!
http://www.deskontrol.net/blog/arduino-based-artnet-node-for-led-pixels/comment-page-4/#comments
Rgb order in FastLED is done at compile time, it cannot be set at runtime.
ok. Could you please check the code link for me in case you can see where I can change the RGB order? I have no idea where to check. thanks!
I can’t right now, but you can look at https://github.com/FastLED/FastLED/wiki/Rgb-calibration and see what you need to do/look for yourself.
I am not sure to what software do you refer to, but I am using arduino ide 0023 for the code, and chamsys magicq to drive the stripes.
Maybe this can help?
// Receive multiple universes via Artnet and control a strip of ws2811 leds via OctoWS2811
// This example may be copied under the terms of the MIT license, see the LICENSE file for details
// https://github.com/natcl/Artnet
// http://forum.pjrc.com/threads/24688-Artnet-to-OctoWS2811?p=55589&viewfull=1#post55589
#include <Artnet.h>
#include <Ethernet.h>
#include <EthernetUdp.h>
#include <SPI.h>
#include <OctoWS2811.h>
// Ideas for improving performance with WIZ820io / WIZ850io Ethernet:
// https://forum.pjrc.com/threads/45760-E1-31-sACN-Ethernet-DMX-Performance-help-6-Universe-Limit-improvements
// OctoWS2811 settings
const int ledsPerStrip = 492; // change for your setup
const byte numStrips= 1; // change for your setup
DMAMEM int displayMemory[ledsPerStrip*6];
This file has been truncated. show original
I can tell you many people have used it successfully in large LED projects.
thank you very much!
We are already succesfully driving the Leds. The only thing is that Ic oculdnt find the way to calibrate RGB in the older version of the library “FastSPI_LED”
The calibration in “FastLED” is pretty straight forward, and I am missing how to do it in “FastSPI_LED”
Ah! That’s you’re problem - you should stop using FastSPI_LED and move to FastLED (preferrably the 3.1 branch). I didn’t add the rgb re-ordering until FastLED.
