Hi, I was just reading up again on some leveling stuff and found some confusing stuff in the documentation. Specifically, this is about leveling “only_by_two_corners”. Is G31 or G32 currently the right command for that?
The documentation for “only_by_two_corners” was changed quite a while ago from G31 to G32.
Here’s the comparison link http://smoothieware.org/pcb-milling?do=diff&rev2%5B0%5D=1495482950&rev2%5B1%5D=1551994398&difftype=sidebyside
My own probing script which I wrote longish ago uses G31 for probing by two corners.
I believe there was something like that, either the documentation, or the code was changed a while back, I think to fix a mistake made previously where it was the wrong Gcode talked about, or used.
bool CartGridStrategy::handleGcode(Gcode *gcode)
if(gcode->has_g) {
if(gcode->g == 31 || gcode->g == 32) { // do a grid probe
Looks like both G31 and G32 should work. But the usage of G31/G32 varies between probing strategies.
I think it would probably be good to at least update the “supported g-codes” page. G32 should be more broadly defined as a probing related command with the actual purpose depending on the configured strategy; plus add a link to the Z Probe page. (Basically, the same as the description for G31).
Maybe it would also be nice to add some note on the PCB milling/only_by_two_corners page about the change of the command. That should help to prevent confusion.
I wanted to offer to do that if it sounds alright to you. But I just noticed that the documentation is read-only now.
I added the G32 mention like you suggested, and please feel free to improve things in any way you see fit, it’s very welcome. It shouldn’t be read-only if you create an account.
