Actually those functions help me do the animation for sure but does not help me in the issue that I tried to explain - but thanks for your feedback!
To clarify what I need: I need to know the current color of each LED in my strip without handling/managing a huge array.
Does that make sense?
Any suggestions?
Thanks!
I went through colorutils but can’t find the function I am looking to do and would like your advice on the best way to implement it.
I use a “base” color for all my LEDs HSV=168,170,30.
Randomly some LEDs change color but after I want those LEDs that changed color to fade back to the “base” color at a speed dependant on the gap between the colors- ex if the led that changed color are at HSV=160,70,70 - I want it to do a first loop at HSV=164,120,50 and on until going to the base color HSV=168,170,30.
It is sort of a fade to black but to a specific color and with a fading % dependant on the gap between the HSV values…
Thanks for your feedback - currently I am building all this from scratch but by using existing functions there might be an easier path that I don’t see currently!
Sounds like it would be pretty. I wrote something similar where I created a base colour of blue, with flashes of white that fade back to blue for starcloth style effect. I will try and have a look later to see if it could be adapted easily for your effect
