Hello
My Name is Meik and I hope you can help me.
I use a Smoothieboard 5XC with BLTouch.
If I will start the Probe leveling-strategy.rectangular-grid the x,y,z turn to min. Position.
The Z-Probe to not start the probeding.
The Probe Offeset between the nozel and the BLTouch is 4,1mm.
I think I have a bug in the config…
Thanks for the help
I start the Prozess with:
G28
M280 S3.24
G32
I use the actual firmeware.
Here is my config:
switch.bltouch.enable true #
switch.bltouch.output_pin 1.23 # sw pwm can use any digital pin
switch.bltouch.input_on_command M280 #
switch.bltouch.input_off_command M281 #
switch.bltouch.output_type swpwm # sw pwm must be low frequency
switch.bltouch.pwm_period_ms 20 # 50Hz
switch.bltouch.startup_state false # start up in the stow state
switch.bltouch.startup_value 7.43 # On boot it will go into stow mode, also set with the M281
switch.bltouch.default_on_value 3.3 # if M280 is issued without S this is the value it will set it to
# Z-probe
# See http://smoothieware.org/zprobe
gamma_min_endstop nc # normally 1.28. Change to nc to prevent conflict, not needed on Azteeg X5
zprobe.enable true # set to true to enable a zprobe
zprobe.probe_pin 1.28^ # pin probe is attached to if NC remove the !, Azteeg X5 this is 1.29
zprobe.slow_feedrate 5 # mm/sec probe feed rate
#zprobe.debounce_ms 1 # set if noisy
zprobe.fast_feedrate 50 # move feedrate
zprobe.probe_height 5 # how much above bed to start probe NB only needed for G32 on delta
zprobe.return_feedrate 0 # feedrate after a probe, default 0 is double of slow_feedrate (mm/s)
zprobe.max_z 555.3 # maximum default travel for the probe command, will use gamma_max if not defined
# Levelling strategy
leveling-strategy.rectangular-grid.enable true # The strategy must be enabled in the config, as well as the zprobe module.
leveling-strategy.rectangular-grid.x_size 460 # size of bed in the X axis
leveling-strategy.rectangular-grid.y_size 470 # size of bed in the Y axis
leveling-strategy.rectangular-grid.size 7 # The size of the grid, for example, 7 causes a 7x7 grid with 49 points.
# Must be an odd number.
leveling-strategy.rectangular-grid.do_home true
leveling-strategy.rectangular-grid.probe_offsets 21,53,4.1 # Optional probe offsets x,y,z, from the nozzle or tool head
leveling-strategy.rectangular-grid.save true # If the saved grid is to be loaded on boot then this must be set to true
leveling-strategy.rectangular-grid.initial_height 10 # will move to Z10 before the first probe
mm_per_line_segment 1 # necessary for cartesians using rectangular-grid
leveling-strategy.rectangular-grid.before_probe_gcode M280 # uncomment if you have a bltouch
leveling-strategy.rectangular-grid.after_probe_gcode M281 # uncomment if you have a bltouch
