When you create a new topic post you have the option to add tags to your post. This is a great feature that allows you to easily find posts that deal with the same subject.
Currently you can add up to 10 tags to a post. When you select “optional tags” it shows you a list of current tags you can search or you can create a new one.
If you create a new tag please keep in mind that this is a multiple discipline maker community so there are likely to be generic tags that would overlap. To keep it from getting messy, we request that you create unique tags for each discipline/sub group (e.g. K40-shop-tips, CNC-shop-tips, 3D-shop-tips etc.). Admins will be keeping an eye on this and make adjustments as needed. Thank you in advance
