I bought a Chinese laser cutter from Alibaba, and I had few problems.
When I start the machine, it keeps going back on the Y axis even though it’s home, and it makes a really loud noise, also my pc isn’t recognizing the machine.
There was a usb with the machine, the supplier told me I need to plug it in to make the pc recognize the machine, I don’t know how is this possible, I haven’t tried it yet and I thought I should get help.
You have to install the driver on your computer. I suspect that is on the USB key.
The loud sound when the machine homes are often caused by the endstop optical switch in the upper left not working.
This can be caused by the flag that interrupts the sensor being bent and or the sensor is damaged.
I just found out why it keeps coming home, there was a cable unconnected. However, when I press test on the machine it won’t fire. Do I need to install a driver to fire the laser?
