Compressor for air-assist:
First I’ve bought a big air compressor (24l tank, 8 bar pressure), because I thought it should be fine, I can set the pressure… I had to buy some filter (to avoid water/oil in the air), and some accessories. I’ve used it with pressure regulated to ~1 bar, but even with this small, constant airflow it had to run too frequent. It was loud, very loud.
So I bought an aco-328, just received it and plugged in to try it. It is more than enough. (Maybe even the aco-318 would have been enough, but I always want the bigger :D)
Yes I know, everybody said, that the small one (aco) is enough, they were right…
